Hi, im trying to replicate some SQL querys from old database in Access. The actual database is in PostGIS. The problem is there a first query, and the second one is making a join from first one's results.
  • Dec 5, 2023 7:55 AM UTC
  • 103 views
pabloolivaresm
The firs one query is first query
And the second one is second queryThen I need to do a join with this second query and create a list with the results.
I dont know if with the SQL Executor transformer I can replicate this two querys.
Any idea?
Thanks
Best answer by ctredinnick
Yeah, you should be able to write it in one statement using a CTE. ie
with _FME_Gare_ETC_SQ as (
SELECT ...
SELECT ...
FROM Gare LEFT JOIN _FME_Gare_ETC_SQ ON ...
ctredinnick
Forum|alt.badge.img+22
  • Dec 5, 2023 8:19 AM UTC
SELECT ...
SELECT ...
pabloolivaresm
SELECT ...
SELECT ...
yeah! thanks @ctredinnick​ I tryed in PGADMIN4 and it works fine. In FME I had to add some file as iniciator for SQL Executor.
Thanks
