Hi, I would like to test the condition if with the @stringlength function. Test condition: If the length of the "section" attribut is equal to 2 then keep the attribute value. If not add ‘0’ before the attribute value. My query doesnt work.
Can you help me to find the solution?
Thanks,
Best answer by stefanh
You don't need the @Evaluate part in the Test.
This works
tomfriedl
Forum|alt.badge.img+13
  • December 13, 2022
Without Test-condition:
Transformer StringFormatter, Format String: 02s
  • December 13, 2022
I use the "AttributeManager" transformer with Test-condition.
stefanh
Forum|alt.badge.img+8
  • December 13, 2022
In this case the StringPadder - Transformer might also be the solution.
  • December 13, 2022
Capture
  • December 13, 2022
Need to add a new transformer ? Not possible to do with AttributeManager and Test-condition ?
stefanh
  • December 13, 2022
This looks good. Is it working?
There is also the @PadLeft StringFunction you can use in the AttributeManager.
tomfriedl
  • December 13, 2022
I think FME is confusing the brackets in the attribute identifiers.
your condition is
@StringLength(@Value(Section (R ...))) 2 = @Value( ...
What does the 2 (at this position) stand for?
  • December 13, 2022
Not this position.
The 2 means 2 characters
tomfriedl
  • December 13, 2022
Test conditon: @StringLength(@Value(test))=1
Value: 0@Value(test)
else do nothing.
  • December 13, 2022
else do nothing.
non change
tomfriedl
  • December 13, 2022
This works:
StringLengthMaybe you can share your workbench/data?
stefanh
  • December 13, 2022
This works
  • December 13, 2022
This works
thank you i understand
