Hi All. I have a Civil 3D file that has block data that contains several attributes. When I set the parameters to explode blocks to entities all the attribute information is lost. Is there anyway to preserve the attributes?
If I do not explode, I loose the 3d surface and the geometry is shown as point.
JennaKAtSafe
Forum|alt.badge.img+8
Hi @awais​, The AttributeKeeper might solve your problem. Place it in between the AttributeExploder and your Output and select the attributes you'd like to keep (name, geometry, etc). Hope this helped!
  • October 13, 2021
I am loosing the values inside the attributes. Attribute fields I can see after exploding.
