Help with multiple LEFT JOIN using InlineQuerier
  • Apr 29, 2021 12:54 AM UTC
  • 134 views
TABLE AHi, I have a question about how to perform a Multiple LEFT JOIN, because I need to categorize certain ROWs of my TABLE A (all the fields always have information), based on the combination of criteria that I have in TABLE B, the categories are defined in the column RESPONSIBLE TEAM of TABLE B, many of the fields in TABLE B are empty and when this is the case, it is possible to select any value (wildcard), if I do a simple LEFT JOIN it works correctly, but I can't do more than two LEFT JOIN to be able to do the categorization I need.
I am using InlineQuerier.
this is what I am using:
select * from "TABLE A"
LEFT JOIN "TABLE B"
on "Country" like "_Country"
and "State" like "_State" is not null or '%'
and "City" like "_City" is not null or '%'
and "CODE" like "_CODE" is not null or '%'
and "Description" like "_Description" is not null or '%'
and "Exp Comment" like "_Exp Comment" is not null or '%'
and "Condition" like "_Condition" is not null or '%'
and "User" like "_User" is not null or '%'
Could you take a look and help me with this, please?
TABLE B
connecter
Forum|alt.badge.img+10
  • Apr 29, 2021 8:55 PM UTC
Hi @diello​ ,
if I understand you right- have you tried to separete it?
First query
UNION ALL
Second query
  • Apr 29, 2021 9:49 PM UTC
Hi @diello​ ,
First query
UNION ALL
Second query
Hello @connecter​ could you guide me with a small example?
connecter
  • Apr 30, 2021 5:34 AM UTC
Hello again,
I'm not a good as SQL, I often use UNION ALL to combine selects in the InlineQuerier like this:
LEFT JOIN "TABLE B" on "Country" like "_Country"
UNION ALL
LEFT JOIN "TABLE on "State" like "_State"  is not null or '%'
UNION ALL
select * ....
