Help with JSONTemplater using sub-templates
  • Nov 4, 2024 4:34 PM UTC
  • 274 views
sandor
Hi All,
I’m using the JSONTemplater and I am getting the following errors from FME when it parses the root template:
JSONTemplater (XMLTemplaterFactory): The following error occurred near line 81, column 59 of the query:
JSONTemplater (XMLTemplaterFactory): "fme.get-attribute": function with arity 1 not declared
In the root template, I have the following starting on line 80:
    "Subfeature1Array": [
    fme:process-features("Subfeature-First", "xxxNumber", fme.get-attribute("xxxNumber"))
    "Subfeature2Array": [
    fme:process-features("SecondFt", "xxxNumber", fme.get-attribute("xxxNumber"))
    "Subfeature3Array": [
    fme:process-features("ThirdFeat", "xxxNumber", fme.get-attribute("xxxNumber"))
Both the root features and the sub-features have an xxxNumber attribute.  I am following what is documented in the Help for the JSONTemplater “Selecting the Sub-Features to Process” section example but have no clue what the issue is.
Any help would be greatly appreciated!
sandor
  • Nov 4, 2024 6:09 PM UTC
<sigh>  Nevermind… I just realized that somewhere along the way the colon that comes after fme got changed to a period.  <head slap>
sar_copp
Forum|alt.badge.img+5
  • Jan 31, 2025 2:12 PM UTC
Are you perhaps able to share images of the JSON Templater X query for the root and sub templates. Im new to this and interested!
sandor
  • Jan 31, 2025 4:20 PM UTC
Disclaimer: This was my first experience using FME to work with JSON, so I am not sure what I’ve done is necessarily the best approach.
So I used the JSONFlattener to break out the properties of the JSON root node for the root template.  I used the JSONExtractor to break out the sub-nodes in my JSON that would be used for the sub-templates.  I then used a JSONFragmenter to break out the properties of each node.
Given a JSON file that starts like this:
   “property1” : “value”,
   “property2” : [
       “property3” : “value”
The JSON XQueries I used for the JSONExtractor were like the following:
json[“property1”]
json[“property2”]
The JSON XQueries I used for the JSONFragmenter was simply json[*].
In the JSONFragmenters, I specified the property names I wanted to expose in the output for each JSONFragmenter.
For the JSONTemplater, I had the output from the JSONFlattener providing the JSON for the root template and the output from each of the JSONFragmenters providing the JSON for each of the sub-templates.  I created JSON files for each of the templates.  The following is an excerpt from one of those templates:
"Address": {
  "BuildingUnitIdentifier": fme:get-attribute("Owner.Address.ApartmentNumber"),
  "CivicSiteStreetNumber": fme:get-attribute("Owner.Address.BuildingNumber"),
  "CivicSiteStNoSuffix": fme:get-attribute("Owner.Address.BuildingNumberSuffix"),
I hope this helps you.
