Help with configuring attribute splitter to skip specific delimiters
  • Jul 22, 2022 12:23 PM UTC
  • 98 views
I'm having trouble using AttributeSplitter to split everything with a semicolon as delimiter, EXPCEPT skip seimcolon's that are within parentheses. Please help! Thanks!
Example 1424462 (EXT: 1488296; 1491537); 1428106; 1436651; 1436653
What I need is:
1428106
1436651
1436653
Best answer by dustin
Here is a possible solution, although it assumes the parenthesis will be in the first list element. I've attached my test workbench that you could copy the transformers from.image
dustin
Forum|alt.badge.img+36
  • Jul 22, 2022 1:29 PM UTC
Forum|alt.badge.img+54
  • Jul 22, 2022 1:30 PM UTC
I would usually do something like regex to replace the delimiters outside the brackets with a different delimiter with a StringReplacer and then use that in the attribute splitter
I think this should match semi colons outside of brackets
This worked! Thank you very much!
@bgossett127​ or a single StringReplacer with the regex ( \\(EXT:([ 0-9]+;?)+\\)) replaced with <blank> to remove the extensions and then followed by the AttributeSplitter to split the remaining string
