Hello! Is it possible to extract coordinate pairs (lat/lon) that are within an actual shapefile boundary as opposed to using a bounding box of a shapefile? When I use the BoundsExtractor transformer I'm getting more points than warranted. Thanks.
  • Apr 9, 2021 7:28 PM UTC
  • 69 views
Best answer by rahulsharma
Hello Rahul, the coordinate pairs are in a large SQL database. I just would like to extract the pairs that fall within the extent of the shapefile. The coordinate pairs are not in a shapefile and do not intend to convert them into a shapefile. I hope the clarification helps.
Ok in that case, you can use the following steps
Read SQL Data (assuming its non-spatial)
Convert the Lat\\Long to Point using VertexCreator
Use transformers such as Clipper or SpatialFilter (or others suchas PointOnAreaOverlayer)
Clipper will be best option and just look under Inside port.
Hope this helps
rahulsharma
Forum|alt.badge.img+12
Hi @robeesafe​, To clarify what I understood from the question is that you want just get all the lat/long pairing of the features in the Shape file.
Use GeometryExtractortransformer, to convert the geometry in OGCWKT
This will create an attributes (_geometry) which should contain Lat/long values for shape polygon
 The value should be stored for each feature.
  • Apr 9, 2021 8:11 PM UTC
rahulsharma
  • Apr 9, 2021 9:18 PM UTC
Hope this helps
