Hello, I would like to enhance my points with skp tree models. I have used the solitaryvegetationobject workspace and output is being in a high file size when CityGML format was used. How can I write the output in CityJSON format using this worksp
  • Sep 28, 2022 7:22 AM UTC
  • 42 views
geoinspiration
Forum|alt.badge.img+9
When I try to produce CityGML file and then convert it to CityJSON, the file size gets bigger instead of reducing. Makeinstances workspace is also producing CityJSON file with same inputs in a very big size. Is there any option to reduce CityGML file size by converting it to CityJSON in FME?
