Hello guys, I have data in a gdb and I have classified it using a test filter. Which transformer or writer format can I use to output my results in a summarized table?
  • Sep 8, 2023 4:57 AM UTC
  • 41 views
j.botterill
Forum|alt.badge.img+69
  • Sep 8, 2023 6:58 AM UTC
Hi melvingeno, you have two choices:
  1. Add a Writer and sepecify Automatic mode, assuming you want the same output schema/attribute definition
  2. Or you can add a workflow transformer = FeatureWriter. Specify the format to Excel? and give it an output path. The beauty of the feature writer is that you can connect each output from the testfilte to the ports of the feature writer.
Here is an article about the feature writer and simple example FME Community (safe.com)
Cheers,
James
