Group by attribute match_id to sum values
  • Aug 24, 2022 12:46 PM UTC
  • 442 views
acusig
Participant
I've a bunch of features relative to adresses and associated inhabitants.
I've already grouped the features by similar street names and numbers wich results in the "match_id" column.
What I need now is to sum each four "total..." column's value (separately) by using the "match_id" as grouping value.
The goal is to get the number of peoples, etc ..., living at one adress.
I've tried several transformers after the AttibuteManager but none return the attented values.
Thanks for your help
Best answer by tomfriedl
Use the Aggregator.
tomfriedl
Forum|alt.badge.img+14
  • Aug 24, 2022 1:18 PM UTC
Use the Aggregator.
acusig
Participant
  • Participant
  • Aug 24, 2022 1:31 PM UTC
I've tried it with different options but it always returned me 1 big grouped feature. I was just using the wrong settings ...
Thanks !
