Grid Shift Files
  • May 24, 2013
  • 65 views
Has anybody had issues with the Reprojector? I'm converting some shapefiles from EPSG:4617 to CANA83-10TM115 into a GeoMedia SQL Server Warehouse.
I'm getting the error
"Reprojection from 'LLCSRS' to 'CANA83-10TM115' requires grid shift file(s) for datum transformation" Reprojector: Could not create reprojection engine
Any thoughts?
Best answer by fmelizard
Looks like the reprojection you are doing needs some definitions that dont automatically come with FME and should be added.
The documentation described how to add shift files.
Hope this helps.
fmelizard
Forum|alt.badge.img+22
  • May 24, 2013
Hope this helps.
