graph analysis
  • Jan 22, 2020 2:55 PM UTC
  • 0 replies
  • 37 views
Hello!
I am wondering how can I use FME to analyse graphe?
I have points that represent a surface and I would like to analyse these surfaces with local maximum and/or minimum. But the surfaces are not always simple, some of them is almost like a line, but some of them are like a roof - as represented on the picture.
Is there any way to fit a line to these points, and analyse the parameters of these lines, like determinant.
Or is there any algorithm that could compare these generated lines with sample functions?
Do you have any advice?
