Get number of days in month
Forum|alt.badge.img+4
@takashi I have a dataset like this:
DateValue01/01/2018201/01/2018001/05/2018301/12/2018102/01/2018302/02/20184
I want to create an attribute for Daily Average Value in Each Month, and store the daily average (sum of values within each month ÷ number of days in that month).
The denominator is where I'm having trouble. Any suggestions on the best way to find the number of days within a given month?
Best answer by ebygomm
If you didn't want to use python, you can get the first day of the month then add a month and take away the first date to get number of days
hlouie
Forum|alt.badge.img+16
  • August 24, 2018
I know how to do this in Python
from calendar import monthrange
monthrange(20122)
(229)
Forum|alt.badge.img+39
  • August 24, 2018
  • August 24, 2018
You can also use something like the following in an inline querier if your dates are in ISO format
select aa.*, strftime('%d',date(aa."date",'start of month','+1 month','-1 second')) as days_in_month from Table1 aa;
  • August 24, 2018
Inspired by @egomm's suggestion. Assuming that the original date/time format is %m/%d/%Y.
Depending on locale, the format might be %d/%m/%Y. Please specify the format explicitly, in this kind of question.
  • August 29, 2018
Thanks @egomm and @takashi, I think this should work!
Since I've become such a heavy FME user, I almost always convert all dates to FME format, %Y%m%d before transforming or trying to calculate anything.
