GeoTiff Convert to Shape File
  • Jun 27, 2022 8:42 AM UTC
  • 12 replies
  • 675 views
asadamjad
Participant
Forum|alt.badge.img+12
I have Geotiff file and I need to convert in shape file with data
I am new in this so I don't know how to Extract fields and attributes from Geotiff +
this is the file
https://www.nhc.noaa.gov/gis/inundation/inundation.zip
nielsgerrits
Forum|alt.badge.img+67
Do I understand you want to convert the rastercells to points or polygons? This can be done but will result in a lot of points / polygons. About 5.000.000 for this raster.
Steps how you can do this:
  • Reader or FeatureReader to read the raster.
  • RasterCellCoercer to convert the rastercells to points or polygons.
  • AttributeCreator to convert the raster cell value to attribute. In this case _band{0}.value.
  • Writer or FeatureWriter to write the result to shape.
asadamjad
Participant
  • Participant
  • Jun 27, 2022 11:06 AM UTC
give me null Values
nielsgerrits
give me null Values
Correct. The values are in the list "case _band{0}.value" so you must create an attribute using the AttributeCreator where value is case _band{0}.value.
You can see this in the Feature Information window in the Visual Preview or Data Inspector.
asadamjad
Participant
  • Participant
  • Jun 27, 2022 1:39 PM UTC
still not getting it
nielsgerrits
Attached workspace demonstrating this.
2022-06-27_16h00_33
asadamjad
Participant
  • Participant
  • Jun 28, 2022 8:06 AM UTC
2022-06-27_16h00_33
work perfectly fine
can we merge features with similar category
as in one multipolygon for each category
imageit's like each pixel has been inserted separately as a record
this doesn't seem right
adjoining features need to be merged as a single polygon
that way, they will represent a single region
nielsgerrits
2022-06-27_16h00_33
Merging adjoining polygons with similar attributes can be done using the Dissolver.
asadamjad
Participant
  • Participant
  • Jun 28, 2022 8:30 AM UTC
2022-06-27_16h00_33
but i need in polygon
asadamjad
Participant
  • Participant
  • Jun 28, 2022 8:31 AM UTC
2022-06-27_16h00_33
i am new and i have no idea how can I do that
nielsgerrits
2022-06-27_16h00_33
I think the best advise I can give is to work through the FME Academy first, to get up to speed working with FME.
asadamjad
Participant
  • Participant
  • Jun 28, 2022 10:32 AM UTC
2022-06-27_16h00_33
i am but atm this work is in urgent situation
danminneyatsaf
Forum|alt.badge.img+13
Hi @asadamjad​ Currently in your AttributeCreator, you are assigning "_band{0}.value" to the New Attribute parameter. Instead of assigning it to the New Attribute parameter, try assigning it to the Attribute Value parameter. You can then assign the name of the attribute in the New Attribute parameter.
Hope this helps! - Dan M
