Geotab - SDK intergration - ExceptionEvent - Broken rules
pwiles
Hi all,
I'm using FME to connect to this SDK with a httpcaller transformer. However, if I want to retrieve the ExceptionEvent (where rules are broken), i need to include additional information in my GET.
This is my current get: https://my42.geotab.com/apiv1/Get?ExceptionEventSearch={"database":"xxx","userName":"pwiles@stars.ca","password":"xxx"}
I get a error when trying to use this GET. The error that is returned is the following:
_response_body (encoded: UTF-8): {"error":{"message":"The method \\\\u0022Get\\\\u0022 could not be found. Verify the method name and ensure all method parameters are included.","code":-32601,"data":{"id":"11773710-4ab7-4507-b527-4ad8508f3ea5","type":"MissingMethodException","requestIndex":0},"name":"JSONRPCError","errors":[{"message":"The method \\\\u0022Get\\\\u0022 could not be found. Verify the method name and ensure all method parameters are included.","name":"MissingMethodException"}]},"jsonrpc":"2.0","requestIndex":0}
If I had rules in place for these exceptions and wanted to retrieve the three rule names in the last 5 minutes, how would I write this statement above?
These are the rule names:
TEST ECC: CORP Possible Accident
ECC: CORP Airbag Deployed detected
ECC: CORP Possible Accident ECC
Attached is my workspace that includes the broken Httpcaller.
Geotab's API reference documentation is located in the following location:
https://my.geotab.com/sdk/#/api
Thanks for your time,
Paul
Hi @pwiles,
I took a quick look at the API doc you shared and would recommend to check out this part:
https://my.geotab.com/sdk/#/concepts
I am not familiar with the API at all, but I would try these 2 options as they might be a potential solution:
1. Properly URI encode your query string. In FME this can be done with the TextEncoder
2. Send your request with the POST method in the HTTPCaller and include the GET method you want to use for the API as a key/value pair in the payload of the request as shown in the documentation.
I hope this helps!
pwiles
  • July 26, 2018
gerhardatsafe wrote:
Hi @pwiles,
I hope this helps!
Well, I was able to pull the exceptionevent's by using the following:
https://my.geotab.com/apiv1/Get?typeName=ExceptionEvent&credentials;={"database":"xxx","userName":"pwiles@stars.ca","password":"xxxx"}Then I broke FME inspector. Everytime I try to open inspector it crashes (when viewing this data). I get the following error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: fmeworker.exe
Application Version: 2018.7.34.18310
Application Timestamp: 5b03ca3e
Fault Module Name: fme.dll
Fault Module Version: 2018.7.34.18310
Fault Module Timestamp: 5b03ca30
Exception Code: c0000005
Exception Offset: 00000000013a23e7
OS Version: 6.1.7601.2.1.0.272.7
Locale ID: 1033
Additional Information 1: 9ea6
Additional Information 2: 9ea65f6f178d7eeff7dbf6b25273728e
Additional Information 3: 38d4
Additional Information 4: 38d471de971d3e5107fb2f5ddfe4a015
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid;=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\\Windows\\system32\\en-US\\erofflps.txt
nampreetatsafe
Forum|alt.badge.img+13
Problem signature:
Locale ID: 1033
Hi @pwiles: Would you mind opening a case with our support team (https://www.safe.com/support/report-a-problem)? Please provide the details you've given above, a reference to this post, your workspace and, if possible, use a Recorder (https://www.safe.com/transformers/recorder) to attempt to capture what is being sent to the Data Inspector in a ffs file.
