Georeferenced Image/ Static Map from Image Fetcher
  • May 31, 2020 10:27 AM UTC
  • 95 views
Is it possible to get a georeferenced image/ static map from the image fetcher - or something similar?
I've used the coordinates of a bounding box, and a Bing Maps API key to fetch an image but it isn't georeferenced.
I've tried georeferencing it afterwards but the process completely distorts it so ideally I would like to avoid this step if possible.
Thanks,
A similar question was asked regarding a WMS service. See if you can adapt this to your problem.
https://knowledge.safe.com/questions/113739/extracting-data-from-intramap-viewer.html?childToView=113749#answer-113749
