GeometryValidator fatal error
  • July 6, 2017
  • 53 views
Hallo People, by using GeometryValidator (Self intersections in 2D) FME 2016.1 get an error and Translation fails. Do you have any idea - why? (shape with polygones are attached) Do you have an idea: how can i identify such a polygones to filter from the whole amount of data? As i can see: These are the Polygons with fme_geometry=fme_aggregates and have also fme_donut inside. But i have but this variation also another polygones, which going without error through GeometryValidator.
Here is the error message:
While detecting the issue 'Self-Intersections in 2D', GeometryValidationFactory encountered a fatal error
Thank you!
  • July 6, 2017
Was able to reproduce with FME 2017.0, so you should report this to Safe support as a potential bug.
For this particular case, it seems you can work around the problem by inserting a Deaggregator and a DonutHoleExtractor before the GeometryValidator.
