Geometry Validator sample data
  • May 27, 2013 9:18 AM UTC
  • 114 views
jpvo
Hi FME users,
I am looiking for good geometry examples of any corrupted or errors that can / cannot be cleaned with the Geometry validator 2013.
I found the following list:
https://support.safe.com/hc/en-us/articles/25407709561741-Invalid-OGC-Geometry-Examples
which is a perfect start but i would like to be able to hilghlight the following issues at least:
http://docs.safe.com/fme/html/FME_Transformers/Content/Transformers/geometryvalidator_issues.htm
Does anyone has a complete collection of geometry sample errors?
Thank you.
JP.
Best answer by david_r
Salut JP,
I'd consider contacting Safe about this, perhaps they have a sample dataset they use for unit tests that they'd like to share.
David
  • May 28, 2013 7:41 AM UTC
Salut JP,
David
jpvo
  • Jun 9, 2016 3:05 PM UTC
Eventually I made up some sample data. Any improvement to this is welcome
geomissues-gv.fmw
You will find some artificial geometries with obvious issues and their result through the Geometry Validator.
kweller
Forum|alt.badge.img+8
  • Apr 23, 2022 9:14 PM UTC
Thank you for this! Your sample geometries provided a good start for testing the GeometryValidationHTMLReporter transformer I've since published to FME Hub. https://hub.safe.com/publishers/kweller/transformers/geometryvalidationhtmlreporter
