Geojson file - how to copy the array of features to a new Geojson file?
  • Aug 20, 2024 8:22 AM UTC
  • 83 views
nicola.webb
I am new to FME. I have a geojson file with an array of features - for example under functionalClass i have 6 different modes of transport and under category I have 5 different types of roads. I want to create a new geojson file but using an existing geopackage (with only the attribute field called roadName as a  value) but I need the new geojson file to have the same array of features as the first one. What would be the best way to create this?
I have consider the feature readers and writers, JsonTemplater and JsonFormatter. But I am a bit lost on where to start or what transformer is the best to use in this case? Or is there an easy way to extract the arrays in FME so I can build csv files and just map them using an attributemapper transformer?
Thank you for your time.
hkingsbury
Forum|alt.badge.img+73
  • Aug 20, 2024 10:06 PM UTC
Are you able to share an example of the input datasets and an example of what output you’re after?
