Generating Tabular Results from Multiple Features...
I'm having trouble restructing my (aspatial) data from what I can best describ as multiple rows per uninqe identifer each containing a feild name and respective value to a single row per feature per feature where there field name values become columns. The example below probably explains this better:
---INPUT----
ID,Field,Value
1,FieldA,Cow
1,FieldC,Sheep
2,FieldA,Dog
2,FieldB,Mouse
2,FieldC,Cow
---DESIRED OUTPUT---
ID,FieldA,FieldB,FieldC
1,Cow,,Sheep
2,Dog,Mouse,Cow
Does anyone have any tips as to how this is best don? Aggreagting is based on the ID is easy, but manipulating the resultant list items into the format of the desired output is eluding me.
Regards. Rob.
Best answer by takashi
Hi Rob,
I would use the BulkAttributeRenamer and the Aggregator.
Aggregator
Group By: ID
Mode: Attribute Only
Keep Input Attribute: Yes
Then, you can expose required attribute names (FieldA, FieldB, and FieldC) with the AttributeExposer.
Takashi
gio
Forum|alt.badge.img+15
  • January 30, 2015
You can use the excel writer technique described below (Pratap's question).
ID = xlsx_row_id.
@(Value(@Value(Field)) =@Value(Value)
Input written to csv schema for exposer.
need modern excelwirter for that though (i use fme2014sp2 and newer)
gio
  • January 30, 2015
U can
listbuilder on ID.
Listelementconter.
Attributecreator for a index.
Listindexer in a loop/ customtransformer
Like in previous suggestion, you must create a csv from the input data to use as a schema for the exposer. (import values)
  • January 31, 2015
Hi Rob,
Aggregator
Group By: ID
Takashi
gio
  • January 31, 2015
that techniques is the same as just creating attributes and grouping them:
Attribute_name = @Value(@Value(Field))
Attribute_value = @Value(value).
Don't need a renamer for that.
You then have a table where FIELDB is missing on the first row.
My techniques don't have that flaw.
(unless htat is not a issue....)
Also i would write out the table to a csv (or other format)  and then use it as schema.
Unless you like to manualy expose attributes.
  • February 2, 2015
Gio, Takashi,
Thanks both for your responses. My final approched used Takashi solution, but the AttributeCreator in place as the BulkAttributeRenamer as suggested by Gio Both produce the same result though.
Regards. Rob.
