Generate sequence
  • August 23, 2013
  • 11 replies
  • 503 views
I would like to generate a sequence in a new column.
I have an Excel file with pages and I would like to import this Excel file in 3 tables in Oracle 11g.
In each Oracle table, I would like to have an extra column "OBJECTID", and I would like to fill this column with a sequence starting at 1 (1,2,3,4,5,...).
I don't know how I can do that.
Thank you for your answers!
Fabienne
fmelizard
Forum|alt.badge.img+22
  • August 23, 2013
You can use the counter for that, you can also specify an attribute/feature to create a count by (att/feature).
  • August 23, 2013
Thank you for you answer. But with the counter, I have to specify an input. I would like FME generate automatically a sequence starting at 1.
Is it possile?
Thank you!
Fabienne
fmelizard
  • August 23, 2013
I dont really understand what you mean by automatically...if you specify OBJECTID as you count output attribute and your feature type (fme_feature_type) in the counter name.
This will generate for each feature type a OBJECTID attribute with a count (1,2,3). you should specify that you want to start with 1 in the count start, all FME countings start with zero.
fmelizard
  • August 23, 2013
forgot to mention that you can also use the end sql to let the db creat a sequence
  • August 23, 2013
I don't understand what I have to put as Input of the counter. There's still a red arrow as the input of the counter.
I would like to send you an image to help you to understand what I mean but I didn't manage to send you an image here. Have you en e-mail?
Thank you!
fmelizard
  • August 23, 2013
You can link an image in the thread (see buttons above).
I gather you are reading the xls, the reader has an arrow, connect the reader to the counter (red arrow).
See more about connections of transformers here:
http://docs.safe.com/fme/html/FME_Workbench/Default.htm#Connecting_Transformers.htm
  • August 23, 2013
The image is on my laptop an not on internet. So I cannot link it.
If I link the Reader with the Input of the counter, it doesn't work. Indeed, in this case, the result in my table is:
OBJECTID      TYPE         COLUMN_NAME       DESCRIPTION
(null)                Onglet        Hommes                   données pour les hommes 1                       (null)           (null)                           (null) (null)                Onglet        Femmes                    données pour les femmes
2                       (null)           (null)                           (null)
I would like to have the following in my table:
1                       Onglet        Hommes                   données pour les hommes 2                       Onglet        Femmes                    données pour les femmes
Thank you so much for your help!
  • August 23, 2013
I guess that you connected the Counter to the Reader in parallel to the main feature stream. If so, try re-connecting it on the main stream in a series.
Takashi
  • August 23, 2013
Thank you Takashi.
My counter is in parralel with the arrow from the Excel sheet to the Oracle table, but if I put it in serie, the columns of the Excel sheet and the columns of the Oracle table are not linked anymore.
It is difficult to explain what I have and I cannot put an image to show you my workbench because the image is on my laptop and not on internet.
Do you have an e-mail so that I can send you an image of my workbench?
Thank you!
Fabienne
fmelizard
  • August 23, 2013
Hi Fabienne,
In that case the you can right click on the connection to the writer and select automatically connect.
Also if you have a dropbox account you can upload the image and share it here.
  • August 23, 2013
Thank you so much!
It is working now!!!
Thank you.
Fabienne
