FuzzyStringComparer - many versions - many issues
  • Apr 24, 2017 6:00 PM UTC
  • 11 replies
  • 153 views
sigtill
Forum|alt.badge.img+25
Just to let anyone using the FuzzyStringComparer some hands up with FME2017 - its a real struggle to get it working as it has changed a lot and there are many versions of it. If it does not work - try to right click on it - edit and copy all the transformers to the main workspace.
itay
Forum|alt.badge.img+19
  • Apr 24, 2017 6:06 PM UTC
Hands or heads? :)
I'm struggling with this right now! Any ideas to fix? I get this error:
Python Exception <AttributeError>: 'NoneType' object has no attribute 'lower'
Error encountered while calling function `FuzzyStringCompare'
f_267(PythonFactory): PythonFactory failed to process feature
  • Apr 27, 2017 4:58 AM UTC
Hi @miikamakela, the error occurs when the script tried calling the method called 'lower' on None object. The method should be called on a string object.
I looked at the script in the FuzzyStringComparer and found the error could occur if one of string attributes to be compared was missing actually. Make sure that both string attributes have string value.
Thanks @takashi I will try to fix this! I indeed can have null values in the other field - previously the tool has managed them.
actually, I still did not get this to work by fixing the strings, but the original suggestion by @sigtill to copy transformers to the main workbench and map the attributes works.
Hi guys, I'm having issues with this again.
Now I got this error message:
Python Exception <UnicodeEncodeError>: 'ascii' codec can't encode characters in position 21-25: ordinal not in range(128)
f_274(PythonFactory): PythonFactory failed to process feature
The string contains text in English|Hebrew|Arabic each separated with a | pipe. This seems to be the issue.
Before, with just "normal" characters this python script has worked nicely:
import difflib
def FuzzyStringCompare(feature):
string1 = str(feature.getAttribute('FuzzyStringCompare.string1')or '').lower()
string2 = str(feature.getAttribute('FuzzyStringCompare.string2')or '').lower()
ratio = difflib.SequenceMatcher(None,string1,string2).ratio()
feature.setAttribute('FuzzyStringCompare.ratio',ratio)
Any suggestions how to change it to accommodate the more complex strings?
davideagle
Forum|alt.badge.img+21
  • Jul 7, 2017 7:43 PM UTC
Maybe @DaveAtSafe can help by bundling up some of the versions into a Versioned custom transformer. I'm pretty sure it was one of his originally. He certainly helped me out a while back when one of the two Fuzzy transformers disappeared altogether... It certainly looks like its seen a few edits lately.
daveatsafe
Forum|alt.badge.img+24
  • Jul 10, 2017 6:40 PM UTC
@miikamakela,
I recently updated the transformer to produce a comparison string as well as a ratio. It appears that this code is failing when one of the attributes is missing, and also with the Arabic and Hebrew characters. Would you mind sending me your sample strings, and I will see if I can fix the problem for you.
@miikamakela,
Hi, my colleague adapted the python code so it works now - at least for our use case. He added UTF-8 encoding. See script below.
import difflib
string1 = (feature.getAttribute('FuzzyStringCompare.string1')or '').encode('utf-8').lower() string2 = (feature.getAttribute('FuzzyStringCompare.string2')or '').encode('utf-8').lower()
ratio = difflib.SequenceMatcher(None,string1,string2).ratio() feature.setAttribute('FuzzyStringCompare.ratio',ratio)
daveatsafe
  • Jul 27, 2017 8:49 PM UTC
Hi @sigtill, @
miikamakela,
I have updated the FuzzyStringComparer transformer to handle unicode strings and to fail gracefully when the compare strings are not present on the feature.
Please give it a try and let me know if you have any other problems with it.
Hi @sigtill, @
miikamakela,
Thanks @DaveAtSafe. I will give it a go!
