Formatting number to specific text format
  • October 13, 2018
  • 6 replies
  • 1129 views
Hello,
I'm having difficulty getting the String Formatter to work for me (I'm confident this is the right transformer I need to use.) I am trying to convert values stored as a number such as "23.012" to text in the following format: "000.0000". The destination output being "023.0120".
I'm sure it's incredibly easy, but I've had a play about with it and I'm getting nowhere.
Would be massively grateful for any help.
Thanks!
  • October 13, 2018
Hi @cjones28, you can use the StringFormatter with this format specification.
08.4f
Here, ".4f" specifies that the representation would be a decimal point number with 4 decimal places; "08" specifies that the entire resulting string would be at least eight characters and padded by leading zeros if the string length is less than 8 characters.
danilo_fme
Forum|alt.badge.img+45
  • October 13, 2018
08.4f
Excellent resolution with this transformer StringFormatter @takashi
danilo_fme
  • October 13, 2018
Hi @cjones28
I created a Source file Excel format to simulta your case in 4 possible values.
The Workspace Template file that I created is split the attribute Values and count the elements.
Two Bookmars ( Format 1 and Format 2 ) was created to works prefix and sufix:
Result in FME Data Inspector:
Attached the Workspace Template - FMWT - workspace-format-string.fmwt
Thanks,
Danilo
  • October 16, 2018
@takashi I've tried the suggested method (it might be worth mentioning that the reader in this instance is a CSV file):
Unfortunately the excel output is still appearing in exactly the same format as in the originating CSV.
Thanks
Chris
  • October 16, 2018
Thanks
Chris
You had to mention that the destination format was Excel.
Since Excel automatically removes leading and trailing zeros from numeric values by default, the StringFormatter would not be helpful. Instead, you will have to set a custom format in the Excel writer feature type. e.g.
  • October 16, 2018
Many thanks @takashi!
