Format number with commas
  • Dec 8, 2016 8:55 PM UTC
  • 12 replies
  • 841 views
Is there a transformer that can convert a number into a number with a thousands separator, that is, "1000" to "1,000"? I know you can do it with Python but I can't find a transformer that does this.
Thanks
Best answer by david_r
I see you specifically asked for a non-Python solution, but since it involves several transformers, here's one anyway ;-)
import fmeobjects
def FeatureProcessor(feature):
    value = feature.getAttribute('num') or ''
    try:
        value_str = "{:,}".format(value)
    except ValueError, TypeError:
        value_str = value
    feature.setAttribute('num', value_str)
Assumes input features with an attribute called "num" (change lines 4 and 9 as necessary)
  • Dec 9, 2016 12:23 AM UTC
Hi @jimo, I don't think a single transformer can do that but you can use a series of these transformers here. Assuming that an attribute called "_num" has a numeric value with integer representation:
StringPadder: Pad 0-2 spaces to the left side of the value of "_num" so that the number of characters will be a multiple of 3.
  • Attributes: _num
  • Desired String Length: @ceil(@StringLength(@Value(_num))/3.0)*3
  • Side to Pad: Left
StringReplacer: Replace every three digits with the original three digits and a comma.
  • Attributes: _num
  • Text to Match: (...)
  • Replacement Text: \\1,
  • Use Regular Expressions: yes
AttributeTrimmer: Trim excess leading spaces and trailing comma from the resulting string.
  • Attributes to Trim: _num
  • Trim Type: Both
  • Trim Characters: , <space and comma>
  • Dec 9, 2016 11:16 AM UTC
import fmeobjects
    try:
        value_str = value
  • Dec 9, 2016 11:54 AM UTC
  • Attributes: _num
  • Side to Pad: Left
  • Attributes: _num
  • Replacement Text: \1,
  • Trim Type: Both
Just an experiment. This expression consisting of some FME String/Feature/Math functions works as well as the three transformers.
@Trim(@ReplaceRegEx(@PadLeft(@Value(_num),@Evaluate(@ceil(@StringLength(@Value(_num))/3.0))*3),(...),"\1,")," ,")
And I remember a similar Q&A;: Number Notation
patrick_koning
Forum|alt.badge.img+7
I think the stringformatter is the way to go.
http://docs.safe.com/fme/2016.1/html/FME_Desktop_Documentation/FME_Transformers/Transformers/stringformatter.htm
.4f will be the format in your case
then a stringreplacer to replace the . to ,
Good luck
  • Dec 9, 2016 3:54 PM UTC
Those are all good answers, folks. I was really hoping that there was a single transformer that could do the job. I guess it's a good candidate for a "New Idea".
I try to limit the Python in my scripts because the next person who comes along might not know Python. However, the "{:,}".format(value) suggestion by david_r above seems to be the simplest in the Python realm.
Thanks
nrich_defra
  • Feb 22, 2017 11:37 PM UTC
or ....
if you wanted a single transformer solution, you could use a bit of regex in a string replacer.
this will allow you to use one transformer against multiple attributes on the same feature, although admittedly many people may find the python script easier to maintain than the regex! neat solution though.
in 2015.0
StringReplacer settings
text to match:([0-9])(?=([0-9]{3})+$)
replacement text: \\1,
use reg expression: yes
if attr value does not match: no action
The 'positive lookahead assertion' regex is a modification of the version I found here , someone far cleverer than me worked it out. In my quick tests it worked on 1, 1234, 123456,123456789 adding the multiple commas in the right place if required.
  • Feb 23, 2017 3:59 AM UTC
or ....
in 2015.0
Good catch. Thanks for sharing the elegant regex solution.
  • Mar 1, 2017 10:21 AM UTC
import fmeobjects
    try:
        value_str = value
Alternative solution using just a single StringReplacer and some creative regex:
https://knowledge.safe.com/questions/40697/format-number-from-1000000-to-1-000000.html
  • Mar 1, 2017 10:50 AM UTC
or ....
in 2015.0
replacement text: \1,
Just a heads up, this regex won't work for fractional numbers, only integers. Sample input:
-12345566654.33345
Returns:
-12345566654.33,345
nrich_defra
  • Mar 1, 2017 10:57 AM UTC
-12345566654.33345
Returns:
-12345566654.33,345
Thanks @david_r, yes, good spot.
My data happens to be integers in this instance, but I imagine there is away to incorporate(ignore) the fractions into the regex?
I will just stick an attributerounder in front in my case though!
  • Mar 1, 2017 11:01 AM UTC
For floating point numbers you can try out the regex I posted here:
nielsgerrits
Forum|alt.badge.img+67
import fmeobjects
    try:
        value_str = value
In my case, using python 3.6 it wont work due to ValueError, TypeError, If you remove these it works again.
import fmeobjects
    value = feature.getAttribute('originalValue') or ''
    try:
        value_str = '{:,}'.format(value)
    except:
        value_str = value
    feature.setAttribute('originalValue', value_str)
