FME Workbench unable to write to Temp folder
joe.fme
Forum|alt.badge.img+4
Hi all,
I seem to have an issue with writing to the Temp folder location (E:\\Temp, in this case). I will get an error like the following -
Failed to write feature data to `E:\\temp\\wb-cache-NSPL_V3.2_ShortName-rUhMFp\\Main_FeatureJoiner_20 -1 24 fo 0 JOINED 0 6641bd2679d46e05f371fbb029766a8cafbc270f.ffsupdating'
I've tried creating a new workspace from scratch, renaming it and I am able to copy files to that folder without any issue. I also ran FME Workbench with elevated privileges and as a different user, even with a different Temp location but no success with any of them.
Has anyone here had anything like this occur? And if so, is there a known way to resolve it? I've deleted all Temp files and again, no change. All a bit odd out of nowhere!
Thank you
JennaKAtSafe
Forum|alt.badge.img+7
Hi @joe.fme​ I wonder if this could be that there is not enough space in your temp location. You could try following the directions in this article to set a temporary file location for FME to use via the FME_TEMP environment variable and see how that goes for you.
joe.fme
  • May 30, 2023
Hi Jenna,
Unfortunately I've tried both the E drive (where the FME_Temp environment variable points to) and C:/Temp but with no joy.
It's baffling, as we have scheduled tasks that are running fine. I'm able to clear the temp folders and have permissions on this particular server running Workbench.
Knowing my luck it's something I'm missing but I've thought of every possibility so far.
I got a bit further just copying and pasting the workspace reader/transformers into a new workspace, but it still threw an error about 80% of the way through (whereas before it was when it was about 30% done)
Edit - the C:\\temp issue persists
Error changing to C:\\temp
joe.fme
  • June 2, 2023
Hi Jenna, again, I've tried rebuilding the model, reading in the source data for the joins and the Temp environment variable being changed to another drive but no luck. It just seems to be this 1 workbench as well, as the others (thankfully) work fine.
Proper stumped - any input/ideas/spitball something would be much appreciated. Just all boils down to the Temp folder -
FFS writer: Failed to write to file 'E:\\temp\\wbrun_1685710463911_61604\\fmetmp_7\\FMETable\\FeatureJoiner_1685713198917_56908.fts'. Please ensure that you have sufficient privileges to write this file, and that sufficient disk space is available
FeatureJoiner_20 (FeatureJoinerFactory): Failed to write to file 'E:\\temp\\wbrun_1685710463911_61604\\fmetmp_7\\FMETable\\FeatureJoiner_1685713198917_56908.fts'. Please ensure that you have sufficient privileges to write this file, and that sufficient disk space is available
120GB free and admin permissions :(
brittzucchetto
Were you able to find a solution to this problem? I’m currently having this issue with the FileDeleter transformer. We just upgraded to 2025.0 from 2023.2.4 and am now seeing issues.
raghavendrans
Forum|alt.badge.img+14
@joe.fme
Did you try running the workspace step by step? (run to this)
Meaning up till the first transformer and so on to figure the root cause?
SRG
donalmateer
Hi ​@joe.fme,
Looking into this issue and you mention it only is an issue with this workspace.
If possible are you able to run it without feature caching? The issue could be caused by the data volume or structure going into the FeatureJoiner. Try turning off feature caching and see if you’re able to run the workspace.
If the issue still persists temporarily use a sampler to send a smaller number of records into the FeatureJoiner - let us know if the error still occurs.
