FME server error when running Json
  • Sep 3, 2018 8:31 PM UTC
  • 75 views
boubcher
Forum|alt.badge.img+11
Hello There
the workspace work with no error on the FME desktop but when published on the FME server I am getting this error
(The clause 'JSON_DOCUMENT @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>text_line_data<closeparen>,JSONValidator) READ_FROM_FILE NO FILEPATH_OR_URL <Unused>' within 'FACTORY_DEF * JSONFormatterFactory FACTORY_NAME JSONValidator INPUT FEATURE_TYPE UUIDGenerator_OUTPUT JSON_DOCUMENT @EvaluateExpression(FDIV,STRING_ENCODED,<at>Value<openparen>text_line_data<closeparen>,JSONValidator) READ_FROM_FILE NO FILEPATH_OR_URL <Unused> FORMAT NONE SYNTAX_ERROR_LIST_ATTR _json_error OUTPUT OUTPUT FEATURE_TYPE JSONValidator_PASSED OUTPUT INVALID FEATURE_TYPE JSONValidator_FAILED' is incorrect. The parameter to JSON_DOCUMENT must be a constant value, a value-of (&) attribute, or an FME function call)
Any idea please ??
this is the Json transformaer section of the WS
danilo_fme
Forum|alt.badge.img+58
  • Sep 3, 2018 10:27 PM UTC
Hi @boubcher
Is the same version FME Desktop and FME Server?
Thanks
danilo
  • Sep 4, 2018 7:25 AM UTC
I've observed something very similar with a JSONFlattener when accidentally publishing a workspace made on FME 2018.1 to FME Server 2018.0, so yes, the first thing is to check Desktop and Server versions. On a general note, FME Desktop should never be more recent than your Server version.
Tip for Safe: It would be super cool if FME Server could give a very visible warning if it started a job with a workspace authored by a desktop version more recent than the actual engine build number.
boubcher
  • Sep 5, 2018 1:20 PM UTC
Hi @boubcher
Thanks
danilo
Sure guys we will update the FME server to much the version
Thanks Again
When publishing the workspace workbench does give a warning that you'll be publishing to an older version of Server. But you could always add this to the ideas if it's not there already
