fme:get-json-attribute
  • Oct 15, 2018 2:18 PM UTC
  • 360 views
I'm doing some data conversions using FME Workbench through Data Interoperability, and I'm having issues with the JSONTemplater. I am grabbing a field from a json that contains more json, and I want to leave it unaltered as part of my template. the fme:get-attribute XQuery alters the contents, and fme:get-json-attribute returns an error stating that the data does not contain any JSON text when it does.
My template expression:
    "annotations": fme:get-attribute("annotations"),
    "initialStepId": fme:get-attribute("initialStepID"),
    "initialStepName": fme:get-attribute("initialStepName"),
    "steps":fme:get-attribute("steps"),
    "displayGrid": fme:get-attribute("displayGrid")
And an example set of data for the annotation field:
"annotations" : [ {
"position":"299, 109, 171, 77",
"text":"This is an annotation."
Comes out like this with get-attribute...
\"annotations\" : \"[ {
\\\"position\\\":\\\"299, 109, 171, 77\\\",
\\\"text\\\":\\\"This is an annotation.\\\"
but I get this error with get-json-attribute:
diagram_details_2(XMLTemplaterFactory):
The following error occurred while executing the fme:get-json-attribute function:
diagram_details_2(XMLTemplaterFactory): The attribute 'annotations' did not contain valid JSON text
diagram_details_2(XMLTemplaterFactory): A JSON syntax error was found at line 1, column 0
diagram_details_2(XMLTemplaterFactory): The JSON data is incomplete: Unexpectedly encountered the end of JSON data
diagram_details_2(XMLTemplaterFactory): The data does not contain any JSON text
Anyone familiar with the tool able to help out?
Best answer by takashi
Hi @samjwestfive, as the log messages say, the value of "annotations" attribute is not a valid JSON document.
A possible way is to extract the valid JSON array part from the "annotations" and then get it with the fme:get-json-attribute function in the template. e.g.
See here to learn more about JSON basis: Introducing JSON
Hope this helps.
  • Oct 15, 2018 11:00 PM UTC
Hope this helps.
