FME-Desktop crashes while loading main Window or inside the application.
Hi I'm using FME 2022.2.5 it crashes at the start and before loading the main window, sometimes it happens when I enable/disable cache.
the issue with Qt6Sql_fme.dll ! appcrash event in the the log file.. anyone with helpful tips
 it does start after 5-6 tries.
this log is from the start up crash
Felet uppstod i programmet med namn: fmeworkbench.exe, version 2022.7.45.22795, tidsstämpel 0x6424fcdc
, felet uppstod i modulen med namn: Qt6Sql_fme.dll, version 6.2.4.0, tidsstämpel 0x6254adba
Undantagskod: 0xc0000005
Felförskjutning: 0x000000000000edbf
Process-ID: 0x7968
Programmets starttid: 0x01d98ca438014579
Sökväg till program: C:\\Program Files\\FME\\fmeworkbench.exe
Sökväg till modul: C:\\Program Files\\FME\\Qt6Sql_fme.dll
Rapport-ID: 4320bc12-2030-4046-b3b8-63e036810fb4
Fullständigt namn på felaktigt paket:
Program-ID relativt till felaktigt paket:
Fel-bucket 0, typ 4
Händelsenamn: APPCRASH
Svar: Inte tillgänglig
Kabinett-ID: 0
Problemsignatur:
P1: fmeworkbench.exe
P2: 2022.7.45.22795
P3: 6424fcdc
P4: Qt6Sql_fme.dll
P5: 6.2.4.0
P6: 6254adba
P7: c0000005
P8: 000000000000edbf
P9:
P10:
  • May 29, 2023
i updated FME to 22800 but still same problem now it doesn't start at all
JennaKAtSafe
Forum|alt.badge.img+7
Hi @ghattas111​, thank you for bringing this issue to our attention. Please submit a case through this link. To your case, follow these instructions and attach the FMEreport.html as well.
