FME-Desktop crashes while loading main Window
Show first post
danminneyatsaf
Forum|alt.badge.img+12
@gcodreanu @p-chessel-vdg @d_l would you be able to download and test FME Form 2024.0 for us and see if the issue is resolved in that version? You can find the 2024.0 beta here: https://engage.safe.com/support/downloads/#beta
The “Computer\\HKEY_CURRENT_USER\\SOFTWARE\\Safe Software Inc.\\FME Workbench\\Window States\\2017” registry key likely was causing issues to do with restoring window layouts when opening FME Workbench.
In 2024.0 we are using a different system for restoring windows, so we’d like to know from users who have the issue currently if FME 2024.0 also suffers from the crash.
d_l
  • February 19, 2024
@danminneyatsaf
After restoring the registry key to recreate the crash issue in 2023, I can confirm that 2024.0 beta did NOT suffer from crashing. Issue seems resolved in 2024, 2023 works for me via registry key workaround.
