FME 2016 how to subtract 10 hours from a DATETIME string
  • Feb 14, 2018 3:56 AM UTC
  • 7 replies
  • 285 views
nicholas
Forum|alt.badge.img+14
I have a DATETIME string of the format 20180311140001
Which is YYYYMMDDHHMMSS
How can I subtract 10 hours?
Note: I have FME2016, so I lack the DateTimeCalculator
Once I have calculated the above, I still need to do more tweaking, but that is string manipulation, not a math calculation
Best answer by nielsgerrits
Use DateFormatter to convert from %Y%m%d%H%M%S to %s (Count of seconds since the epoch, expressed as a decimal integer.)
Subtract 36000 (60*60*10) seconds.
Convert back to %Y%m%d%H%M%S.
subtract-from-datetime-2016.fmw
Be aware: This deliberately and consciously ignores leap seconds.
nielsgerrits
Forum|alt.badge.img+67
  • Feb 14, 2018 8:15 AM UTC
  • Feb 14, 2018 9:55 AM UTC
Alternatively, you can also use the "DateTimeCalculator" custom transformer from FME Hub. It has been deprecated since its name is the same as the regular DateTimeCalculator in FME 2017, but it's still available in FME 2016 and earlier.
  • Feb 14, 2018 2:00 PM UTC
Basically the same as @nielsgerrits but all within a python caller transformer.
Except converting the string to python datetime and using timedelta to remove the 10 hours
subtract-from-datetime-python-2016.fmw
nielsgerrits
0684Q00000ArKQNQA3.pngsubtract-from-datetime-python-2016.fmw
Hey @davidrich are you sure this works? When I run this workspace it fails.
2018-02-16 06:51:30|   0.3|  0.0|WARN  |Python Exception <NameError>: global name 'NewTime' is not defined
2018-02-16 06:51:30|   0.3|  0.0|WARN  |Traceback (most recent call last):
  File "<string>", line 15, in input
NameError: global name 'NewTime' is not defined
2018-02-16 06:51:30|   0.3|  0.0|ERROR |Error encountered while calling method `input'
2018-02-16 06:51:30|   0.3|  0.0|FATAL |f_7(PythonFactory): PythonFactory failed to process feature
  • Feb 16, 2018 9:12 AM UTC
Sorry I had renamed a value and didn't change all of them.
nielsgerrits
Thanks, learned something new today :-)
  • Feb 16, 2018 9:46 AM UTC
No problem, also if you ever want to do more complex string input or output, I use this http://strftime.org/ which is all the different inputs or outputs other than "%Y%m%d%H%M%S" such as "%-I:%M:%S %p %d %B %y" which is "7:06:05 AM 30 September 13"
