Finding isolated edges
  • May 6, 2015
  • 5 replies
  • 72 views
Hi there, I'd like to know the simplest way of identifying isolated edges based on different attribute values. See the attached image for an example:
So in essence, I'd like to identify all edges where my attribute is valued as "Y".
Thanks,
gio
Forum|alt.badge.img+15
  • May 6, 2015
Im not sure if i understand the question but is it not just a tester to test for the value?
Or are ther more criteria that identifies it as "isolated"?
To me, an isolated edge would be an edge that does not share a (partial)boundary with another object.
In that case u can use  a spatialrelator to find them  with a list. The list will have only one (ID) entry for that object.
Hi Gio,
Yes, sorry for the lack of clarity. I think I just missed a section a typed for the question. A more accurate description would be all scenarios where an edge with attribute "Y" either connects to nothing, or only connects to edges with attribute “X”.
That’s what I mean with isolated, in the sense that it’s not part of a network of “Y” attribute edges, but instead a loose segement that either connects to only “X” attribute edges, or nothing at all.
Hope that makes more sense, and sorry for the original post's limited information.
  • May 7, 2015
Hi
Have at look at the TopologyBuilder and/or the NetworkTopologyCalculator (check for _network_id), in particular using the Group By clause on your attribute.
David
gio
  • May 7, 2015
using a spatiarelator with intersect criteria and a _list seems sufficient.
Test for attribute = Y.
On the Passed port check the list if it there is any Y in it, for instance with a ListSearcher. Notfound port will yield your result.
  • May 8, 2015
Hi Robbie,
I think it's enough that you think of Y edges only. For example:
Send all the Y edges to a NetworkTopoloyCalculator and connect a Mathcer with this parameter setting.
- Match Geometry: NONE
- Attribute Matching Strategy: Match Selected Attributes
- Selected Attributes: _network_id
The "isolated" edges will be output from the NotMatched port.
Takashi
