Find empty folders
  • Apr 24, 2020 8:16 AM UTC
  • 8 replies
  • 136 views
fikusas
Forum|alt.badge.img+5
I need to find all empty folders. Any hidden system files do not count (for example, Thumbs.db). I tried using Python, but unsuccessfully. Can someone help me on this?
import fme
import fmeobjects
import os
if len(os.listdir(feature.getAttribute('path_directory_windows)') ) == 0:
    feature.setAttribute('Value', 0)
else:
    feature.setAttribute('Value', 1)
Forum|alt.badge.img+54
  • Apr 24, 2020 8:26 AM UTC
Where is the path_directory_windows coming from? If you are using the Path Reader to just read in directories, the directory is actually stored in path_windows
  • Apr 24, 2020 8:45 AM UTC
In addition to what @ebygomm said, you'll also have to wrap the Python code into a small function, e.g.
import fmeobjects
import os
def processFeature(feature):
    if len(os.listdir(feature.getAttribute('path_windows'))) == 0:
    else:
In the PythonCaller, type "processFeature" in the setting for "Class of function to process features".
fikusas
  • Apr 24, 2020 8:54 AM UTC
import fmeobjects
import os
    else:
Getting this error:
2020-04-24 11:50:06|   0.8|  0.3|ERROR |Python Exception <SyntaxError>: invalid syntax (<string>, line 6)
2020-04-24 11:50:06|   0.8|  0.0|FATAL |PythonCaller (PythonFactory): PythonFactory failed to process feature
  • Apr 24, 2020 9:01 AM UTC
Getting this error:
There's an errant bracket
swap line 5 with this
if len(os.listdir(feature.getAttribute('path_windows')))==0:
fikusas
  • Apr 24, 2020 9:07 AM UTC
Now it's working, but gives value '1' if folder contains any hidden system files. But actually folder is empty.
  • Apr 24, 2020 9:16 AM UTC
If you want to exclude all hidden and system files, you'll have to dig into OS-specific functions. On Windows that would mean installing and using the win32api Python modules, which aren't installed with FME. (Example here: https://stackoverflow.com/a/14063074)
If the number of hidden files is known and of reasonable length, then you can manually exclude them with a list of known filenames to ignore, like so:
import fmeobjects
import os
FILES_TO_IGNORE = ('THUMBS.DB', 'HIDDEN_FILE_NO1.TXT')
    all_files = os.listdir(feature.getAttribute('path_windows'))
    files = [f for f in all_files if not f.upper() in FILES_TO_IGNORE]
    if len(files) == 0:
    else:
  • Apr 24, 2020 9:18 AM UTC
Thanks! Fixed.
fikusas
  • Apr 24, 2020 9:23 AM UTC
import fmeobjects
import os
    if len(files) == 0:
    else:
This works like a charm. Thanks!
