Find and replace words in a text with words from a list
  • Dec 12, 2022 8:16 AM UTC
  • 11 replies
  • 603 views
michiedem
Forum|alt.badge.img+7
I have a text that randomly has numerals and text for numbering. So the text can be:
20 trees will be planted of which ten will be oaks.
I want to replace all numerals that are in text with numbers, so I get:
20 trees will be planted of which 10 will be oaks.
I already have a csv (with the numbers as numerals and in text) which I could use to merge. I was thinking about putting every single word in the text in a list and the matching all words with the csv with a loop, but this will be very data heavy.
Any suggestions to do this in a clean way?
Best answer by nielsgerrits
The StringPairReplacer is built for just this.
egge
Forum|alt.badge.img+14
  • Dec 12, 2022 9:23 AM UTC
Maybe a PythonCaller? Recently, we have been playing around with the opposite, i.e. converting numbers to words and we have found the num2words · PyPI library to get this done.
For your case you might have a look at the word2number · PyPI lib instead.
An alternative Python solution -  using loop + join() + split() - is given on this page: Python | Convert numeric words to numbers.
nielsgerrits
Forum|alt.badge.img+67
  • Dec 12, 2022 9:34 AM UTC
michiedem
  • Dec 12, 2022 9:38 AM UTC
As far as I know the stringreplacer can be used to replace one value with another. So only ten with 10 for instance. I have a whole list of values (1 to 100 written in letters) that need to be replaced with values from a list (1 - 100 as numerals). I do not know beforehand which of the values will have to be replaced per feature, so I think stringreplacer won't work?
michiedem
  • Dec 12, 2022 9:40 AM UTC
I think the first solution should work for text that are in English, mine is in Dutch unfortunately. The second suggestion might work!
nielsgerrits
Please check the documentation, the StringPairReplacer uses key value pairs:
For example, if the source attribute’s value was:
bobby
and the replacement pairs were:
b s o a
the result will contain:
sassy
So your input should be
one 1 two 2 three 3 etc...
michiedem
  • Dec 12, 2022 9:53 AM UTC
You are right! I missed that, thank you very much!
nielsgerrits
Cheers!
Forum|alt.badge.img+54
  • Dec 12, 2022 2:01 PM UTC
The only thing to be aware of with the StringPairReplacer is it will match partial words, so if you are looking to replace the word 10 with 10 and also have the word e.g. often that will become of10
nielsgerrits
Sharp.
michiedem
  • Dec 12, 2022 3:16 PM UTC
I thought about that (since it will alos happen with twentyone for example, it will become 201), I can use the stringreplacer to replace all spaces by an underscore, so:
_ten_trees_will_be_replaced_by_twentyone_bushes>
_ten_ 10 _eleven_ 11 will be my input
geomancer
Forum|alt.badge.img+71
  • Dec 13, 2022 6:32 AM UTC
Won't you miss words at the start of the line, and just before punctuation marks?
Three_shall_be_the_number_thou_shalt_count,_and_the_number_of_the_counting_shall_be_three.
Four_shalt_thou_not_count,_neither_count_thou_two,_excepting_that_thou_then_proceed_to_three.
Five_is_right_out.
