Filter data using a date field
  • Dec 10, 2024 2:37 PM UTC
  • 243 views
dilip
Forum|alt.badge.img+5
I am looking to extract data from AGOL to store in a separate table and filter the data by its date field. Essentially I will schedule this every evening to collate all the data with todays date, or run this early morning and filter onΒ β€˜Yesterdays’ date. How do I configure the tester transformer to reflect what I need.Β
Β
Any help is greatly appreciated,
Best answer by birgit
I made an example for you. Basically you use the DateTimeCalculator to calculate yesterday. Then you say that your date needs to be higher then yesterday in the tester and you set the comparison mode in the tester to Date/Time.
birgit
Forum|alt.badge.img+25
  • Dec 10, 2024 3:33 PM UTC
dilip
  • Dec 13, 2024 1:52 PM UTC
Thank you :)
