Field Calculate in FME
  • Oct 31, 2018 5:19 PM UTC
  • 373 views
Hello,
I have a .cal file saved in python to create a unique identifier. How can I use this in FME? I didn't create this so I don't know how to tie this to the field needed.
In Arcmap I could just right click the field I want this to go in and field calculate it, but how would I use this to update attributes with nulls in a specific field within fme.
import uuid
def f():
return "{" + str(uuid.uuid4()).upper() + "}"
__esri_field_calculator_splitter__
f()
Best answer by david_r
In a PythonCaller you can do:
import uuid
def FeatureProcessor(feature):
    value = uuid.uuid4()
    feature.setAttribute('my_uuid', '{%s}' % value)
This will add the attribute 'my_uuid' to every feature that passes through.
erik_jan
Forum|alt.badge.img+26
  • Oct 31, 2018 5:23 PM UTC
I believe the PythonCaller transformer could call this script.
  • Oct 31, 2018 5:42 PM UTC
import uuid
Ended up using UUID generator instead of the python script in combination with Attributemanager.
