FeatureReader schema update, dynamically, automatically, csv columns
  • August 10, 2023
  • 8 replies
  • 291 views
paetzold_s
Forum|alt.badge.img+4
I have the following problem:
I have multiple csv files with multiple columns. I want to dynamically change which columns to read.
I have a user parameter to define which columns to read.
Even though the " Attributes to Expose" Parameter of my FeatureReader gets updated correctly the Reader dosn't read the correct columns.
Only after opening the properties of the Reader and closing it again by clicking "Ok" the Read reads the correct columns.
I'm using FME Desktop 2020.2.3.0 on Windows 10
Maybe someone can tell me if this is a bug or if I'm just overlooking something.
Many thanks in advance !
Best answer by danminneyatsaf
@paetzold_s​
After some discussion with our developers, it looks like this is expected behavior with the FeatureReader. Attributes to expose only affects the authoring environment (the GUI you're editing the transformers in) and doesn't change at runtime. To change which attributes are exposed, you'll need to reopen the FeatureReader and click ok after changing the user parameter's value. As a result we've closed the ticket I shared above.
Let me know if you have any follow up questions or clarification.
Dan
danminneyatsaf
Forum|alt.badge.img+13
Hey @paetzold_s​ this looks like a bug to me. I've reproduce the issue and have filed an issue to get this resolved. For your reference, the issue number is FMEFORM-29210. We'll make sure to update you here when the issue has been resolved.
paetzold_s
  • August 11, 2023
Wow, thank you for the quick response. I have found a similar problem with the BulkAttributeRenamer. I'll post it in a new question/thread.
danminneyatsaf
No problem! If you're able to tag me in the question that'd be great. I can take a look and see if the two issues are related.
paetzold_s
  • August 14, 2023
I wasn't sure how to tag/dm you (new to the Forum) so I'll post the link to the second question here:
https://community.safe.com/s/question/0D5Dm00000na4VYKAY/bulkattributerenamer-dynamically-rename-attributes
geomancer
Forum|alt.badge.img+63
  • August 14, 2023
I notice that you have Feature Cashing active. Does the problem also occur when Feature Caching is off?
paetzold_s
  • August 15, 2023
Yes this also happens if Feature Cashing is turned off (tested by writing the output to a csv file).
danminneyatsaf
  • August 15, 2023
@paetzold_s​
Dan
paetzold_s
  • August 16, 2023
@paetzold_s​
Dan
Thank you for the clarification. This behavior is a bit unintuitve.
If this is the expected behavior how can I model this functionality? I have csv files which don't have a common structure. So at the start of the workflow I prompt the user to set the column numbers for the relevant columns. Then I rename these columns and do further processing.
I have 2 potential workarounds:
1) - Set the columns to be exposed by the FeatureReader to e.g. "col0 col1 ... col999"
- rename the relevant columns in an AttributeManager
- filter out all other columns with an AttributeKeeper
2) - open the csv file as a txt file
- insert a new header at the top e.g. ;;;relevant_Col_1;;relevant_Col_2;;;;;relevant_Col_3
- expose the cols "relevant_Col_1", "relevant_Col_2" and "relevant_Col_3"
both solutions seem a bit inelegant. is there a better way I'm missing?
