FeatureReader - Read all SHP within ZIP file (Subfolder)
  • May 10, 2024 10:41 AM UTC
  • 345 views
galigis
Forum|alt.badge.img+22
Hi All,
I’m having a bit of headache to read all the SHP included within a ZIP through the FeatureReader transformer, I’m getting the following error Shapefile and cannot be read for some reason. I can reader it with the normal SHP reader but can’t get it to work on FeatureReader, here is a screenshot of the settings:
What am I doing wrong?
galigis
  • May 10, 2024 11:11 AM UTC
 I have been able to read the folders within the ZIP file but now the second FeatureReader fails because can’t find the temp files? Why is it going to temp files? screenshot below:
jkr_wrk
Forum|alt.badge.img+37
  • May 10, 2024 7:31 PM UTC
Reading directly from a ZIP file means FME extracts the data from the ZIP file to a temporary folder to be able to read the contents.
It could be that the temp file extraction is removed after the first reader is read into cache. Have you tried reading the contents of the zip without featureCaching?
galigis
  • May 13, 2024 9:48 AM UTC
Thanks @jkr_wrk I think I was able to achieve what I wanted by adding the expression [**\*.shp] in the dataset and modifying the published parameters to files. The expression allows to search through the ZIP file and find the extension .shp.
Below a screenshot for completeness:
hkingsbury
Forum|alt.badge.img+73
  • May 13, 2024 8:44 PM UTC
@galigis Thats the correct approach. FME treats ZIP files as folders, so the path to open a shp in a zip will always need to end with *.shp but can include a *.zip as a parent
