feature reader has table but there is no data
  • Nov 4, 2022 7:26 PM UTC
  • 8 replies
  • 172 views
asadamjad
Participant
Forum|alt.badge.img+12
I have a workspace where I gather the data from the web and upload on data base
whenever data available my script run and load the data on the database with truncate.
now the issue is on the source table remove the data until new data is not available
so when I run the script the feature reader shows me nothing. so how can I truncate as well until new data is not available?
as you can see Advisory Wind don't have records from source so if there is record i need to truncate my table image
@asadamjad​ There is a NoFeaturesTester custom transformer on FME HUB that you can use to test for when not features are received. Then you can do something like run a SQL script using SQLExecutor to truncate your tables.
asadamjad
Participant
  • Participant
  • Nov 4, 2022 9:15 PM UTC
i cant use sql Script as i m get data from web
asadamjad
Participant
  • Participant
  • Nov 4, 2022 9:23 PM UTC
This transformation is okay, but I am not looking at this.
When inserted, hit the feature reader and know the feature is empty or has a record. image
asadamjad
Participant
  • Participant
  • Nov 5, 2022 7:05 AM UTC
anyone
@asadamjad​ You could use the SQLExecutor to truncate the tables on the target database
asadamjad
Participant
  • Participant
  • Nov 8, 2022 10:25 AM UTC
How ?? i mean what logic i used
geomancer
Forum|alt.badge.img+71
  • Nov 8, 2022 12:47 PM UTC
Something like this?
No data? --> Truncate the table in the SQLExecuter
Data? --> Truncate the table in the FeatureWriter
No_Features_Flow
asadamjad
Participant
  • Participant
  • Nov 11, 2022 11:09 AM UTC
i can see ArcGis Portal Service in SQL Excuter
