Feature Merger not merging two features
  • November 30, 2019
  • 179 views
I am trying to merge two lot of attributes but when using FeatureMerger, it is only picking up the requestor attributes and the Supplier attribute of 'issue' keeps repeating '36'.
Thanks
Bill
Best answer by takashi
You can use the FeatureMerger to collect issues from all the matched suppliers for each requestor and store them into a list attribute, then concatenate every element of the list using the ListConcatenator. Does it fit to your requirement?
  • November 30, 2019
Hi @sbarn, the FeatureMerger merges a single supplier feature for each requestor feature. If you need to duplicate each requestor feature for every matched supplier, a possible way is to create a list attribute to save all the attributes from matched features and explode it with the ListExploder after. See the Generate List option in the FeatureMerger.
However, I think the FeatureJointer could be a better solution in your case, like this.
  • November 30, 2019
Hi @takashi thank-you for this. However I only want 624 rows returned. So I end up with columns Assessor, Assessment, Category and Issue returned for each row.
  • November 30, 2019
  • December 1, 2019
Brilliant @takashi , thank-you it worked a treat, also like your clear diagrams for me to follow.
