Fatal error message during export from MicroSation GeoGraphics format. Access querry feiles.
During export from MicroStation GeoGraphic I get this error message from the GG-reader:
Microsoft Access Reader: Opening `H:\Produksjon\Kart\2017\Roar_data\Prosjekt\Data\Testdata\Input\TAB\ParksExport.mdb' for read operation
Microsoft Access Reader: Query failed, possibly due to a malformed statement.  Query Text `SELECT * FROM PARKS WHERE PARKS.MAPID = (SELECT MSLINK FROM MAPS WHERE MAPS.MAPNAME LIKE 'ParksExport.dgn')'. Provider error `(-2147217865) The Microsoft Access database engine cannot find the input table or query 'MAPS'. Make sure it exists and that its name is spelled correctly.'
A fatal error has occurred. Check the logfile above for details
@Relate: Failed to execute prefetch query. Continuing with incomplete cache
Microsoft Access Reader: Database read complete.  Retrieved 1 feature(s)
This happens for several Reader formats.
I converted Parks.tab from the training dataset, to GG, and tried to convert back to TAB.
The errormessage comes from the GG-reader.
- What makes this happend?
-Does i cause any real problems? (data seems OK)
Could it be that the mdb is incomplete? If you open the mdb file using MS Access (or using FME and the Access reader), do you see a table called "maps"?
Here's more info about the metadata tables that are expected:
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/mge/mge.htm
Thanks for answer!
There is no table called "maps". There are Feature, MSCATALOG, PArks and UGGEATURE.
In Parks there is a coloumn called MAPID, but all records are emty.
The problem is why the MAP table is not created. My tests WS's have only two elements a reader and a writer.
