Extracting the coordinate index nearest to point
  • Jan 25, 2024 3:42 PM UTC
  • 40 views
bkgg
Hey guys,
I have a fairly large dataset of lines and points. The points need to receive the Z coordinate from the nearest index on the line. Using the CoordinateExtractor followed by a ListExploder isn't an option because that would be too heavy for my workspace.
Isn't it possible to use the CoordinateExtractor in a way that in the setting 'Specify coordinate' you only extract the index that is nearest to a point feature? Is there a different way to go about this?
danilo_fme
Forum|alt.badge.img+58
  • Jan 25, 2024 4:32 PM UTC
Hi @bkgg​
Did you use the transformer NeighborFinder?
