Extracting specific attributes from a data list?
  • Sep 9, 2019 2:55 PM UTC
  • 8 replies
  • 891 views
mda
Forum|alt.badge.img+7
@takashi
I have a list of data as the attached xls sheet. I need to extract specific attributes which come many times in the list. The list contains attributes with the value [name:(different names)] and under this one there are attributes start with the value (string:......). I need to loop through this list and extract the attribute which has the value (name:USED_DATA) with all attributes underneath it which start with (string:.....). The rest I don't need it. The list contains information about many objects. Each object has index starts with 0. So, each object has attributes which I need to extract. Unfortunately, the attribute with the value (name:USED_DATA) comes with different index (so not regular) and this is why I can't use an existing transformer in FME to do what I need or at least to my knowledge. Could you please guys help me with it. Maybe there is a trick to do so which I couldn't find. Looking forward to hear from you!
Kind Regards,,,
Forum|alt.badge.img+54
  • Sep 9, 2019 3:03 PM UTC
You should be able to use the adjacent feature option in an attributecreator to create groupings
mda
  • Sep 9, 2019 5:32 PM UTC
Thanks for your quick response!
I tried to do what you have suggested. However I don't get a (feature[-1].Group) attribute. I just get the attributes which can be seen in the attachment. Could you please tell me how can I get it.
mda
  • Sep 9, 2019 5:59 PM UTC
One more thing. I do see the (feature[-1].Group) before I start fill in the if condition with (_extended_data_list) attribute. However, after adjusting the first if condition, the (feature[-1].Group)attribute disappears.
  • Sep 9, 2019 6:51 PM UTC
If you add another attributecreator in front creating a blank attribute of Group you'll then be able to select it in the second attributecreator. You can create a blank attribute a line up in the existing attributecreator, but fme will tell you you have an invalid transformer but it will work
mda
  • Sep 9, 2019 7:43 PM UTC
Hi @egomm,
Now I create grouping for each set of atrributes which have the values of (name:..........., & string:........). There are many name:..... attributes but I just need one of them per every object. This attribute called exactly (name:USER_DATA) and the attributes beneath it which start with (string:.....). and the rest I don't want it. Do you have a tip on how to extract just those attributes I need. In the attached photos, I drew a line around the data I need. This data comes many time in the list and I need to extract it all. Do you have tips to do this. Thanks a lot!
  • Sep 9, 2019 8:18 PM UTC
Hi @egomm,
You could alter your conditional value so that the rows that start with name:USED DATA are treated differently
e.g.
You could then use a tester to get rid of any features with a value of ignore
mda
  • Sep 9, 2019 9:02 PM UTC
e.g.
I tried it but it results in the following:
So all the values in Group is "ignore". The name:USER_DATA doesn't treated differently.
mda
  • Sep 9, 2019 9:27 PM UTC
Dear @egomm,
It is solved now. I used regular expressions in the condition and now it works. Thanks a lot for the tip.
