extracting link from html xquery issue.
  • Aug 30, 2022 6:55 PM UTC
  • 5 replies
  • 104 views
johnglick
Forum|alt.badge.img+7
I'm attempting to extract a link from html that looks something like this: <a class="email-link" href="https://app.myapp.com/results/a7696ced77454dd39d8241e79f981b3d">here</a>. using the xquery extractor. the x-query //a/@href seems to work in the online testers but not in FME. Any ideas?
Best answer by debbiatsafe
Hi @johnglick​
The rejection message on the rejected feature from XMLXQueryExtractor with the XQuery expression //a/@href is "...can not serialize attribute node".
Searching this error led to this StackOverflow answer. It seems the error is caused by serializing certain result types. Using either of the two functions mentioned in the answer, data() or string(), on the attribute does allow the XMLXQueryExtractor to successfully complete (eg. //a/data(@href) or //a/string(@href).
I'll note it is also possible to use the HTMLExtractor to extract URLs as an alternative to the XMLXQueryExtractor.
Use the XQuery expression //a/data(@href) in the XMLXQueryExtractor or CSS selector a[href] in HTMLExtractor
hkingsbury
Forum|alt.badge.img+73
  • Aug 30, 2022 8:11 PM UTC
Another option would be to use the StringSearcher and regular expression
https://rubular.com/r/EmlvM3VidvKFl3
johnglick
  • Aug 30, 2022 8:48 PM UTC
Certainly an acceptable work around. I'm curious as to why the xquery doesn't work, any ideas?
hkingsbury
  • Aug 30, 2022 9:18 PM UTC
I'll be honest, never used xquery before, so i'm not much help there!
debbiatsafe
Forum|alt.badge.img+24
  • Aug 31, 2022 12:17 AM UTC
Hi @johnglick​
johnglick
  • Sep 1, 2022 12:08 AM UTC
Hi @johnglick​
Thanks! I never realized it was possible to put a parameter other than "Whole" or "Part" in the Tag Part/HTML Attribute area of the HTML extractor. Thanks to your input I can now eliminate a transformer from my workflow!
