Extracting attributes from HTML within KML with photos
  • Nov 16, 2021 11:27 PM UTC
  • 119 views
mapper
Forum|alt.badge.img+7
Hello
I am having trouble extracting attributes from a kml for the features that have photos.
I am using XQuery similar to this example https://community.safe.com/s/question/0D54Q0000848CTkSAM/extracting-information-from-different-folders-in-kml-to-convert-to-the-shapefile
That method works for the features that don't have photos but the features that have photos seem to have a extra section in the HTML that is causing my XQuery to fail.
The Xquery I am using is :
declare default element namespace "http://www.w3.org/1999/xhtml";
for $x in /html/body/table/tr/td/table/tr
return fme:set-attribute($x/td[1]/text(),$x/td[2]/text())
I am pretty sure I just need to modify the Xquery
Best answer by ebygomm
If you just want to ignore the parts with a link you could do something like this
let $values :=  /html/body/table/tr/td/table/tr
for $v in $values
let $attrname:= $v/td[1][not(a)]
let $attrval:=$v/td[2]/text()
return fme:set-attribute($attrname,$attrval)
danilo_fme
Forum|alt.badge.img+58
  • Nov 17, 2021 12:15 AM UTC
Hi @mapper​
Please, could you share a same data example?
Thanks in Advance,
Danilo
Forum|alt.badge.img+54
  • Nov 17, 2021 10:54 AM UTC
for $v in $values
mapper
  • Nov 17, 2021 3:13 PM UTC
for $v in $values
This worked perfectly! Thank you!
