Extract polygon from raster file
  • May 24, 2016 2:50 PM UTC
  • 117 views
danilo_fme
Forum|alt.badge.img+58
Hello all,
I want to extract a polygon features from a raster file. I know that has the transformer RastertoPolygonCoercer makes this job. The problem is that my raster file has _num_rows = 8701 and _num_columns = 5889, and this process is not work because the memory crash.
My raster file has a pixel Blank pixel RGB = 254, and i dont need this pixel value. My question is: has a way to remove this blank pixel RGB = 254 before to use the transformer RastertoPolygonCoercer?
Best answer by ebygomm
You can use the RasterBandNodataSetter and then set the extract nodata values parameter to No in the RasterToPolygonCoercer
Forum|alt.badge.img+54
  • May 24, 2016 3:11 PM UTC
danilo_fme
  • May 24, 2016 4:49 PM UTC
Thanks @egomm It works with the transformer RasterBandNoDataSetter :)
