Extract point elevation data into shapefile from rasterdata
  • May 11, 2021 10:07 AM UTC
  • 70 views
Im trying to extract point data into a ESRI shapefile from rasterdata, but i'm very unsure what transformers I should be using? I've been laborating with rastercellcoercer and coordinateextractor but I just can't get it to work. Anyhone have an idé where to start? I could need a push in the right direction at the moment.
nielsgerrits
Forum|alt.badge.img+67
Multiple ways to do this, depending on what you need.
  • All cells to points:
    • RasterCellCoercer
    • PointCloudCombiner
  • Specific cell to point:
    • PointOnRasterValueExtractor
I suspect you need a 3D point shapefile.
When you use RasterCellCoercer you need to add an AttributeExposer to expose the band value you need. Probably _band{0}.value. Then you need a 3DForcer to put bring the points Z to _band{0}.value.
I think the fastest way is to use the PointCloudCombiner followed by a PointCloudCoercer.
Attached sample workspace.
  • May 11, 2021 11:49 AM UTC
Thank you nielsgerrits, I'll be sure to try that out. And you are correct I need 3D point shapefile.
