Extract muliple values from elements in xml, nested in an attribute
  • Sep 25, 2020 7:55 AM UTC
  • 76 views
pzwaag_wf
I have downloaded a non spatial table called OpenbareRuimteLabel. In this
table a column imgeo_openbare_ruimte_naam is included. In this column the name of the street, location of the label (in RD-coordinates) and the angle to be used for placement of the label is described.
It is no problem to extract the streetname (unique value), however the elements 'pos' (coordinates) and 'hoek' (angle in degrees) can have multiple values.
Is there a possibility to create a row for each individual location (point)
in a new table?
Many thanks in advance.
Kind regards,
Pim van der Zwaag.
Forum|alt.badge.img+54
  • Sep 25, 2020 8:09 AM UTC
The XMLFragmenter will create multiple features for each matched element
pzwaag_wf
  • Oct 6, 2020 9:18 AM UTC
​thanks! that worked but raises another issue. but this should be solved relatively easy.
