Extract attributes and value from XML
  • November 28, 2018
  • 6 replies
  • 45 views
boubcher
Forum|alt.badge.img+11
we use An API call in order to get information from a GIS app, the response we get is an XML,
we want to convert to attribute
I used the many of the transformers there but didn't get the expected result
how we could extract all the attributes from the XML and their value
this is the XML we are getting from the rest API response we get
danilo_fme
Forum|alt.badge.img+45
  • November 28, 2018
Hi @boubcher
Could you save this file with xml extension and structure xml?
Thanks,
Danilo
boubcher
  • November 28, 2018
boubcher
  • November 28, 2018
danilo_fme wrote:
Hi @boubcher
Thanks,
Danilo
sure just added the file data
danilo_fme
  • November 28, 2018
@boubcher Thanks your data.
I received your data and changed it incluiding in the end this xml the tag <\\layers>.
After I read this file in Workbench.
Thanks,
Danilo
boubcher
  • November 28, 2018
Thanks,
Danilo
@danilo_fme
did you use a simple XML reader or XML Flatnner , could you please share the WS ,
danilo_fme
  • November 29, 2018
boubcher wrote:
@danilo_fme
I used the Reader XML - Parameters - Elements to Match
Thanks,
Danilo
