Extract attribute mapping from old FME workbench
  • Feb 25, 2020 9:30 AM UTC
  • 72 views
We have a FME workbench where CSV input is being translated to Shapefiles. This workbench has manually created mapping of attributes e.g. Nominal_Diameter on input and NOM_DIAM on output.
Due to some issues with the old workbench I'm trying to re-create the process. And for that I need the attribute name mapping. But I don't want to do it manually as it will take a considerate amount of time.
Is there a way how to extract this information from the workbench? E.g. as a text:
feature, original attribute name, new attribute name
Thanks, Jan
  • Feb 25, 2020 9:38 AM UTC
You can use the FME Workspace Reader to analyze the contents of your .fmw and e.g. save all the attribute mappings to a separate file.
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/fmw/fmw.htm
Forum|alt.badge.img+63
Depending on how old the workspace is and whether or not it can still be opened in Workbench: if you right click the connection where the mapping is being done and pick the option "Replace with AttributeCopier / AttributeManager" it'll place a transformer there to do that mapping, you can then copy and paste that into a new workspace.
  • Feb 25, 2020 10:20 AM UTC
Sounds good. Thanks for the suggestions. I'll try those.
