ExpressionEvaluator: How to extract a value out of a List-Attribut which has different List-numbers?
  • Jul 28, 2021 2:57 PM UTC
  • 7 replies
  • 631 views
With this Expression I get the max-value of the 5 first List-values.
@max(@Value(FID{0}.FID),@Value(FID{1}.FID),@Value(FID{2}.FID),@Value(FID{3}.FID),@Value(FID{4}.FID))
But the features have different List-Numbers. Some of them 5, some of them more than 5. Is there a way to express not hard-coded? Where the Number of List-entries can be dynamic?
My solution to get the maximum value was the Listsorter. But I wonder, if there is a way with the ExpressionEvaluator. An expression which is not hard-coded seems to be very powerfull.
Thanks for help!
alexlynch3450
Forum|alt.badge.img+16
Did you only want statistics from list? use ListSummer.
or did you want to find the max 'elements' contained in list? use ListElementCounter
or did you want to find a value and return index of value? use ListSearcher and AttributeCreator -= _list{@Value(_list_index)}
alexlynch3450
you can also combine listsorter and listelementcounter to grab feature's last known index feature.
  • Jul 29, 2021 10:19 AM UTC
FID_ModelNameIn this case I was looking for the maximum value in the list (not the maximum index, the maximum value). I know you can get that with the Listsorter. The same result you get with the ExressionEvaluator and the expression:
With this expression, you test only the values from five list-item(index 0 to 4).
I wonder now, if there is a possibility to make an expression with a variable number of list-item.
In the picture you see the values from the attribut model_name, which I use for group by. With the FID I make a list. Out of this list I want to take the maximum FID.
alexlynch3450
why don't you explode list, and run it through StatisticsCalculator- enable group processing @Value(MODEL_NAME)?
geomancer
Forum|alt.badge.img+71
  • Jul 30, 2021 7:22 AM UTC
The ListSorter transformer, with sorting order set to Descending, will put the highest value in item 0. Next you can extract the value of item 0 with the ListIndexer transformer.
If you don't want to sort your list, you can make a copy of it with the ListCopier transformer, and use the copy for sorting and extracting.
Edit: Ah, re-reading your question I now realise you already know how to use the ListSorter
geomancer
  • Jul 30, 2021 9:35 AM UTC
Even more simple: the ListRangeExtractor transformer extracts the minimum and maximum values from a list.
But this is still a solution that does not use the ExpressionEvaluator from your initial question.
Unfortunately something like @max(@Value(_list{}.MyValues)) does not work.
  • Aug 2, 2021 3:28 PM UTC
ok, thank's for answering. anyway, it seems with list-elements it's not the idea to work with the expression evaluator.
